Sound Off - Board Theme
Use this forum for general topics or ones that aren't covered by any other forums. This forum is also for off-topic non-dragon related discussions.
Choose your style:
Poll ended at Wed Oct 05, 2005 7:27 pm
ambience_x
2
17%
BBTech
4
33%
imagize_x
0
No votes
oivar_x
0
No votes
SubSilver
3
25%
tren_z_expanded
3
25%
vision_x
0
No votes
jasidogdotcom
0
No votes
GrayEye
0
No votes
Eos Expanded
0
No votes
Total votes: 12
Post by Tempest »
<center><applet code="countdown.class" CODEBASE="http://dragnix.net/java-sys" width="203" height="21">
<param name="font" value="lcdb0">
<param name="year" value=2005>
<param name="month" value=10>
<param name="day" value=5>
<param name="hour" value=1>
</applet></center>
Okay, everyone, in your profile, near the bottom in the Preference section, there is something called "Board Style". You should see several new board style available there. Try them and select the one you would like to see as default on the board. I will update and work on the layout of the two most popular (one dark, one light), the other will be updated less often.
Now it is time to chose one default board theme.
Want to add a theme that isn't showed here? There is "Demo" of theme available for you to see there: http://www.phpbb.com/phpBB/catdb.php?db=2
Post the URL next to this message and I will update the list.
Note that some of them as as-it, meaning they still have the default title and image. Obviously I won't keep the picture of Master Chief if we decide to use vision_x as the default board theme. Same for every other theme. The icons set (ie: Popular, New posts, No New posts, Locked, Sticky, etc) will be the one used on the SubSilver for the light colored theme (see the image below).
<center>Image</center>
Lastly: This poll will remain open for 30 days, so you have plenty of time to look around and get the feeling of each theme. So, don't cast your vote too early because you can only vote once!
Master Old Dragon
Post by Serenity »
So for clarification, all of these templates are now indefinately available, but you will only be spending time to improve the two (one dark one light) that get the most votes?
And I just noticed the little dragon guy is back!!! W00t to that!!! When did that happen?
Post by Tempest »
Indefinitely available, yes and no, I plan to remove the themes that received no vote at all.
The two themes that will receive the most vote (if it's 2 light, then I will pick a dark one) will be updated more often, the others... well, it will be when I have some free time.
Note: The little title dragon is here since... 7 August 2005.
Note 2: People vote too quickly.
Master Old Dragon
Post by Serenity »
Note 2 Response: I've been all around the themes for phpBB earlier, seen all of what was in the "Board Style" preference tab, and this is the one I liked best before you put the polls up, so I really have spent the time on deciding. Maybe that's the case for the other two votes as well?
Note 3: I think we should give the little title dragon a name.
Tightwad
Location: Under your bed with a really, really big knife
Post by Chalgrish »
George?
ooh! or David
Master Old Dragon
Post by White Dragon Alorith »
We should vote on that too.
"Sure Satan is king of sin and has all the powers of Hell . . . But can he see why kids love cinnamon toast crunch?"
Post by Tempest »
To name the little title dragon, use this thread:
http://www.dragnix.net/Msg_Board/phpBB/ ... .php?t=211
To discuss about the theme, use the current thread.
Master Old Dragon
After spending a bit of time using a few of the board themes, I think I'd rather stick with the defult theme (black one) or use this one.
http://www.phpbb.com/styles/forum/index.php?style=154
Both are darker and easier to see with out having your eyes burned out. I use the net at night more often than not so a white background is more bright than usual.
Post by Tempest »
* Poll options updated *
Post by Tempest »
Apparently, I will be casting the vote for the missing "light" theme and I am a bit surprised that Subsilver get any votes, personally I think it's a rather bland theme, shipped by default with phpBB... It's not something original but if people here want it, so be it.
The Endless Prophet
Post by Silentiea »
I like either BBTech or the Tren_z_expanded one, but I voted for BBTech.
"Thunder is good, thunder is impressive, but it's lightning that does the work." ~Samuel Clemens
Mah Griffon is © Todd Lockwood.
